Large Truck My truck is bigger than yours. The forum for 2+ ton trucks (all years), COE's, Louisville's, Big-Job's etc.
Side window channel molding ?
Old Aug 12, 2020 | 10:32 PM
RustyTrustyF150's Avatar
RustyTrustyF150
Any one know a supplier for the side window channel molding for F-600's ? I found F-500 window channel trim but that supplier don't guarantee it will work ? What difference is there in cab window trim on 1974 models ?
Old Aug 12, 2020 | 10:37 PM
85e150's Avatar
85e150
In many years trim like that and other cab parts interchange from F100 to F1000. If he cabs look the same, they are the same. Not to say there isn't a difference in some stuff, but the window channel trim is probably a safe bet.
Old Aug 13, 2020 | 01:56 AM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
What is a side window channel moulding? I've never seen or heard of any such thing.
The door glass is retained to the window channel with glass tape, available from any auto glass shop.
There are belt weatherstrips (also known as cat whiskers or anti-rattlers), these clip onto the inside of the doors, butt up against the glass. There are inners and outers.
If this is what you are referring to, they are the same 1973/79 F100/880 and 1978/79 Bronco and are reproduced by Carpenter.
D3TZ-1021452-A Right Inner // D3TZ-1021453-A Left Inner // D3TZ-1021456-B Right Outer // D3TZ-1021457-B Left Outer .. Belt Weatherstrips.
The problem is, the reproducers do not list parts for 500 and larger series trucks, even if the same as F100/350.
Old Aug 13, 2020 | 11:06 AM
RustyTrustyF150
ah , your last sentence says it all . You got my gist of what I was referring to . I should have clarified door window molding instead of side window . My bad .
Walston
Apr 29, 2022 07:49 PM
Vinford
Sep 15, 2013 09:42 PM
wannavan
Apr 4, 2013 07:04 PM
mfire138
Ford Truck Parts for Sale
Oct 31, 2012 10:14 AM
