NP435 Transmission issues
Old Aug 11, 2020 | 05:01 PM
SanDeuon's Avatar
SanDeuon
I’ve got a NP435/300-6 out of a Bombardier Muskeg. It’s not an original install.
Trans was making some noise and slipping out of first gear.
Pulled the top and the input shaft seems a bit sloppy. Measured the gap between the 2nd and 3rd gears and it’s around .075, creating a lot of slop on the bearing. I don’t see any shims installed to take up the slack.
Suggestions/advice?
Old Aug 11, 2020 | 06:59 PM
Tom's Avatar
Tom
Suggestions/advice?
Welcome to FTE, SanDeuon!
I split your post into its own thread in a more appropriate forum, you’ll get a much better response when we can talk about your issue directly instead of confusing it with the other thread.
Old Aug 11, 2020 | 08:12 PM
85e150's Avatar
85e150
Rebuild kits are available. There were at least two versions of these for Ford. One for pickups, the other for mediums. The mediums used a larger input shaft at 1 3/8" vs. 1 1/16" for pickups.
Once you sort that out, you can order a kit.
Josethef100
23
Oct 15, 2019 11:47 AM
dropitlow88
61
Apr 2, 2015 10:02 PM
78 Short Box 460 4x4
Jan 19, 2013 09:05 PM
SCFLATHEAD
13
Oct 24, 2010 10:26 PM
Lukes66
Nov 2, 2009 07:34 AM
