First I hate headers, because they are mainly a high rpm performance part that works in a rpm range I do not use.
Now my Y-pipe cracked and a new one was stupid expensive. I could have gotten a cheap chineese made Y-pipe oem style for $150.
Instead I purchased a cheap chineese set of stainless steel headers. Not shorties, but mid length for $250.
I fully intended to open box look at the shoddy workmanship and send them back. Well I was kinda supprised. Really thick flanges, very good tig welds, and mandrel bent tubes. All in all they LOOKED good.
So I figured I would do a loose install just to see how bad everthing mated up. Well after 8 hrs of disassembly and a loose fitting I was again supprised, as they fit togather very good. Minor tweeting buy unscrewing 1 side and tighting the other was needed.
ISSUES:
All bolts are about 1/4" too short, but do work. In 2 locations I had to use a c clamp to bridge gaps so short bolts could be used.
The 2 bolts supplied to hook y pipe to OEM exhaust were too big and did not fit the holes. I had to use my own bolts there.
Very good deal
8 out of 10
That's because flange bolts are only 1 inch long. I had to spend $90 for the grade 8 header bolts so they will not back out.
PS
Anyone who says they can torque all 20 header bolts is probably fibbing.
