88 bronco engine stalls
Old Oct 20, 2003 | 10:58 AM
termyt00's Avatar
termyt00
i have a 88 bronco ,351 EFI that stalls at stops after it is warmed up. i've checked for loose vacuum found nothing, changed the IAC motor , O2 sensor, MAP sensor and still have'nt figured it out. i've also replaced the throttle body and adjusted the idle control too compensate ,it helps for a while but then goes back to stalling. anyone got any ideas??? also this one had a IAC idle block spacer that i removed that seems too allow adjustment of the IAC idle for some unknown reason? anyone know why this is?
tallahassee bronco
1978 - 1996 Big Bronco
May 25, 2012 04:37 PM
Jlckb5
Nov 7, 2011 07:50 AM
tmcd
Illinois Chapter
Dec 21, 2004 04:45 PM
mossy007
Mar 1, 2004 09:08 AM
termyt00
Oct 22, 2003 12:18 PM
