axle code?
Old Oct 20, 2003 | 10:33 AM
tinkerell's Avatar
tinkerell
axle code?
Can anyone identify this axle code? I tried entering the code on with the expert at ww2.dana.com but it did not bring up anything. I tried a bunch of different ways to enter it but it still didn't work. The code is: 611299-3
Thanks
Old Oct 21, 2003 | 07:31 AM
BigShelby's Avatar
BigShelby
Axle code is on the rating plate on the driver's side door. It will be a 2 or 3 digit/number sequence. What you have sounds like a part number.
Old Oct 22, 2003 | 02:24 PM
79f150custom's Avatar
79f150custom
I am a Dana distributor & I ran your # & it does not come back as a good Bill of Material #. You might want to check it again on your axle & make sure of the numbers. I had to wire brush mine 3 times to read them right.
Old Oct 23, 2003 | 10:40 AM
tinkerell's Avatar
tinkerell
I re-checked the number at it is 611299-3. The reason I am asking is I purchased a 2002 Ford F-250 and was confused since the manual seems to state that it has a Dana 50 but the posts hear seem to state that 2002 Ford F250's came out with the Dana 60. I have been trying to confirm this with my p/n but sofar cannot find it listed anywhere???? I bought the truck used so I want to be sure it still has thje factory front axle.
Old Oct 23, 2003 | 04:09 PM
79f150custom
I ran it again & it stilll doesn't come up. You might have to call a Ford dealer because some of the newer axles made by Dana are only available through the dealer.
