Parking brake cable routing
Old Aug 2, 2020 | 01:01 PM
Jacquesfordf100's Avatar
Jacquesfordf100
Hi all,
Just put in my new steering box and coupler have not tightened any thing down yet an still need to add the clamp for the column but the parking brake cable does not seem to be in the right spot, can any
one confirm? This was how it was when I got it but there's been a lot of stuff in the wrong spot. I'm not a fan of it rubbing on the steering box.
Any help appreciated
Old Aug 2, 2020 | 02:16 PM
Becky_is_a_66's Avatar
Becky_is_a_66
The parking brake cable should be on the other side of the steering box. It appears you have steering column problems too as there is the plastic inner bearing race visible on the shaft. It also looks like the alignment is off and the rag joint is under stress (this could be an optical illusion or related to steering column bearings)
Old Aug 2, 2020 | 08:08 PM
Jacquesfordf100
Thanks, nothing's bolted down yet so probably why it looks off. Still need to put on more parts. Thanks for the info I'll route the cable on the other side.
Old Aug 2, 2020 | 09:51 PM
rdixiemiller's Avatar
rdixiemiller
The rag joint needs to be further engaged, the retaining bolt goes through the recessed area on the steering box shaft.
Old Aug 3, 2020 | 01:10 PM
Thunderkiss1965's Avatar
Thunderkiss1965
Also, for the lower clamp that keeps the bearing where it belongs, Wild Horses Bronco has a stainless steel steering shaft clamp 66-75, item number 2792 for $19.95 plus shipping. It fits our trucks and can be installed with everything else done.
Old Aug 3, 2020 | 01:58 PM
Jacquesfordf100
Nice thanks for the info!
Old Aug 5, 2020 | 08:13 PM
JefflovesF250s's Avatar
JefflovesF250s
Mine is routed correctly, but still touches the steering box. I added power steering from a '67. So I put a length of rubber hose around the cable housing so the rubber protects the housing from rubbing on the box. Jeff
Old Aug 6, 2020 | 05:56 AM
Jacquesfordf100
Good tip thanks, I've found multiple pictures and they all seem to route the cable above the box, I'm going to see what works the best this weekend.
Old Aug 6, 2020 | 09:22 AM
TA455HO's Avatar
TA455HO
Lead Gopher
Here's a picture of a slightly older Ford truck but the cable routing is consistent with later years. Routed between steering gear and inner fender. This picture is of an original truck back in that era.
Old Aug 6, 2020 | 09:23 AM
Jacquesfordf100
Awesome thank you!
k1ttlez
Nov 19, 2019 07:44 PM
artfuldodger
Nov 14, 2019 08:18 AM
Troy_Lee
Feb 26, 2018 09:01 PM
