Sun visor material.
Old Jul 31, 2020 | 04:26 PM
1966F100SC's Avatar
1966F100SC
Sun visor material.
Just acquired a used set of sun visors which all the hardware is there and all good, but they need to be recovered. I see that originally on the outside was made of some type of cardboard. What material is this exactly? I can probably make my own instead of having an upholstery shop do it
Old Jul 31, 2020 | 06:19 PM
ibuzzard's Avatar
ibuzzard
See A Man About A Horse
They cost about 50 bucks a pair for decent reproductions.
https://www.ebay.com/itm/1961-66-FOR...wAAOSwcu5UURYl
Old Jul 31, 2020 | 06:21 PM
1966F100SC's Avatar
1966F100SC
Yeah I know but if it’s possible for me to make it myself, which I know it is, I would much rather do that. Just need to know material
Old Jul 31, 2020 | 06:34 PM
ibuzzard's Avatar
ibuzzard
Standard cabs were a type of hard cardboard. Custom cabs, I think, are vinyl covered with some kind of padding. Pretty sure it would be cheaper to buy the standard visors at 50.00 shipped. Material costs, your skill or lack thereof at having done these previously (read: re-doing them several times)says you’d be money and frustration ahead. But, it’s your dime.
Old Jul 31, 2020 | 07:19 PM
peter sipp's Avatar
peter sipp
Hi 1966F100SC, I say go for it. You can learn a few things that you can use later on, on other jobs/projects. That is my approach. It pays off. I have quite a "collection" of items I have "found" and make useful items with them. In my '65 F100 it used to get very cold on the winter months. One day I walked past a construction dumpster. I saw right on top : a big piece of 3" styrofoam.Then there were several 4'x8' pieces of 1/2" pink ridgid insulation. I went home, hooked up my trailer...hauled it home. Now the 3" of styrofoam is under the front seat. The 1/2" insulation, I fastened to the doors and in front of the doors. On the floor...I put 1/32" layer of rubber down. Then a rug. Also put the rug on the gas tank.
Now the temp is reasonable in winter. I have put in sun visors. They are a stiff type of "card board" looking matl. Not sure exactly. They came out of a '66 F100 I had for parts one time. My standard cab had none.
So, finally...make some and enjoy doing it. Best, Pete
Old Jul 31, 2020 | 08:17 PM
Marfarama's Avatar
Marfarama
i am in the same boat. let me know how yours turn out!
Old Jul 31, 2020 | 10:01 PM
1966F100SC's Avatar
1966F100SC
Thanks guys! I’m dragging my sister to help me out in the hobby lobby, jo anne and other stores like that to find the correct material as well as some piping for the edge.
Then to the Lowe’s to get new fiberboard, luckily I have that left for a template. I understand it may be frustrating and time consuming but if it saves me money I’m all about it.
last issue I know I will run into is how to get a needle through the cardboard. If anyone has some ideas on that also it’s appreciated.
i will keep your updated, speaking of keeping updates I have another thread of mine to update I think!
Old Jul 31, 2020 | 10:16 PM
F100 '64's Avatar
F100 '64
Well I need a set also and am curious to see how they turn out. Best of luck. ~Pat
Old Jul 31, 2020 | 10:38 PM
Christmas's Avatar
Christmas
I made mine with a heavy grade vinyl. Only took a couple of hours. Little dirty but here they are.
Old Jul 31, 2020 | 10:46 PM
Christmas's Avatar
Christmas
This is a set like I used.
Old Jul 31, 2020 | 11:11 PM
1966F100SC's Avatar
1966F100SC
That’s the state of mine currently.
with yours how did you sew the vinyl? Via machine or by hand?
Old Jul 31, 2020 | 11:26 PM
Christmas's Avatar
Christmas
I used a machine to do the main part then turned it inside out slid it on then finished it off by hand. That took the longest. You can make that out in the pics. I also used quilting batting on the inside to give them some volume.
Old Aug 6, 2020 | 11:05 AM
1966F100SC's Avatar
1966F100SC
That’s what I plan to do. Now for the vinyl, is standard marine vinyl fine? Would it be okay to make the seat from that type of vinyl as well?
Old Aug 6, 2020 | 04:42 PM
Christmas's Avatar
Christmas
Marine vinyl is good, UV resistant.
Old Aug 30, 2020 | 08:33 PM
1966F100SC's Avatar
1966F100SC
Here’s a snippet of what I have so far. I replaced the inner board, and am covering it in vinyl, then will be doing a stitch less binding around the
with vinyl adhesive
