Large Truck My truck is bigger than yours. The forum for 2+ ton trucks (all years), COE's, Louisville's, Big-Job's etc.
1996 F800
Old Jul 31, 2020 | 09:07 AM
gilbertson's Avatar
gilbertson
7th Gear
1996 F800
Hello
I recently purchased a 1996 F800 auto dump truck to use on my land to build a pond. The truck was a highway maintenance vehicle so the box is pretty rusty but it only has 113,000 miles on it. On the right side in the front on the engine compartment is container that the line is broken off. The line goes from the container to the intake. I am trying to figure out what this does and if it is needed.
Thank you
Vern
Old Jul 31, 2020 | 10:52 AM
Destroked 450's Avatar
Destroked 450
That’s the cold start aid, it’s a small can of ether that’s injected into the intake to help start the engine in cold weather
There should be a button on the dash to activate it
They worked good when new but become problematic with age, solenoid goes bad or can won’t seal good letting the ether slowly leak out, then when you need it the cam is empty
I recommend you remove it and plug the fitting in the intake
Old Jul 31, 2020 | 01:33 PM
gilbertson's Avatar
gilbertson
7th Gear
Thank you Destroked 450
Old Jul 30, 2024 | 09:37 AM
pwack's Avatar
pwack
1st Gear
1996 Ford F800 dump truck battery
I got a ford f800 dump truck it has no batteries on it what type batteries does it take I believe it takes 2 batteries and hooked parrell
Old Jul 30, 2024 | 11:08 AM
Destroked 450
If diesel it should take Group 31 top stud batteries
Most of those models with diesels take 3 batteries connected in parallel, that’s how my 93 is
Squirrel13
Nov 15, 2018 02:06 PM
TMI
Sep 24, 2015 12:39 PM
bra$$monkey
15
Sep 26, 2014 09:56 PM
dustybumpers
Maryland Chapter
Sep 6, 2010 06:16 PM
bronczilla
Offroad & 4x4
May 7, 2003 03:00 PM
