Brake problems
Old Jul 28, 2020 | 09:10 PM
Luke613760's Avatar
Luke613760
Brake problems
I’m having a problem with the brakes on my 1997 Ford F-250. The problem is when I’m driving a decent distance without touching the brakes then I start using them to slow down they work fine. But if I’m in town or using the brakes often the pedal gets hard as a rock and I can barely stop. I already checked the vacuum pump line and it had suction. Any ideas on what this could be?
Old Jul 29, 2020 | 06:06 AM
Audiowriter's Avatar
Audiowriter
Sounds like the pump is working but weak.
Old Jul 29, 2020 | 08:17 AM
Luke613760's Avatar
Luke613760
So I should start with just replacing the pump?
Old Jul 29, 2020 | 10:44 AM
BuddyBarnes's Avatar
BuddyBarnes
NO. Get a vacuum gauge and check the vacuum. This sounds more like a brake booster to me but do a vacuum test first. You can borrow a vacuum gauge at the local parts house.
Old Jul 29, 2020 | 06:06 PM
paddler's Avatar
paddler
Rock-hard pedal means your problem is in the vacuum assist system, not the hydraulics. So it's NOT master cylinder, lines, fluid, calipers, wheel cylinders, bleeding, etc. Vacuum pump, brake booster, leak in another vacuum line could be the issues.
Old Jul 29, 2020 | 09:15 PM
oldbird1965's Avatar
oldbird1965
If you end up buying a brake booster get a zero loss one.
sean9049
May 22, 2014 11:49 AM
SinisterDom
Dec 10, 2012 06:34 AM
1957F100
20
Jul 14, 2007 11:19 PM
1957F100
Jul 11, 2007 10:47 PM
trike1946
May 20, 2007 03:55 PM
