master cylinder
Old Jul 25, 2020 | 11:50 AM
fluff's Avatar
fluff
master cylinder
can we just add a porportioning valve to a regular all drum manual master cyl. for front discs? or does the master cyl. have to be changed.
thanks
Old Jul 25, 2020 | 02:26 PM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
Originally Posted by fluff
can we just add a proportioning (brake pressure differential) valve to a regular all drum manual master cyl. for front discs? or does the master cyl. have to be changed.
thanks
Brake Pressure Differential Valves used on all 1967 and later vehicles with a dual master cylinder. Drum brakes use a different valve than disc brakes.
Drum brake master cylinder different than disc brake master cylinder. 1973 was the first year that F100 2WD's came with discs.
Old Jul 25, 2020 | 03:32 PM
fluff's Avatar
fluff
much appreciated. thanks
Buckley
Aug 24, 2020 07:53 AM
DougieWebb
Feb 23, 2020 03:37 PM
dogg16
Bronco II
Sep 14, 2004 04:19 PM
