Oil & Lubrication
Limited slip additive?
Old Oct 19, 2003 | 08:15 PM
c96drumm's Avatar
c96drumm
Question Limited slip additive?
I'm going to change the oil in the limited slip differential on my 96 Explorer. The tag on the cover says to use 75W-140 synthetic, so I'm using Mobil 1 75W-140 synthetic. The Mobil website says this:
Recommended for many limited slip applications. For certain high level LS applications, additional limited slip additive may be required if axle chatter is observed.
Any opinions on whether I should use the additive or not?
Old Oct 20, 2003 | 10:05 AM
jimandmandy's Avatar
jimandmandy
Drive it without and if you experience "chatter" put some in. I know this won't be popular here, but the GM additive works best.
Jim
Old Oct 20, 2003 | 03:48 PM
MrBSS's Avatar
MrBSS
Right, you actually want to use as little of the additive as possible in order to have maximum limited slip action.
The only problem is, there's usually no drain plug, so don't fill it up to the brim and then try to put the additive in!
pepito113
2004 - 2008 F150
Feb 7, 2013 09:35 PM
Sarasota
Jul 19, 2012 08:53 AM
wildstang
Feb 14, 2010 05:02 PM
raptor131
Sep 15, 2009 09:31 PM
deano2
Oil & Lubrication
Apr 1, 2005 07:03 PM
