Help in decoding the VIN
Old Jul 22, 2020 | 08:15 PM
Kingcw1966's Avatar
Kingcw1966
Old Jul 23, 2020 | 12:21 AM
apes's Avatar
apes
Trailering
Well a quick Google search indicates that it is 2wd, a 1966 model,
built in Michigan in June 1966
Old Jul 23, 2020 | 04:30 AM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
Originally Posted by Kingcw1966
F10 = F100 2WD
A = 240 1V I-6.
L = Michigan Truck Assembly Plant.
878909 = 1966.
Old Jan 9, 2021 | 09:56 AM
Kingcw1966's Avatar
Kingcw1966
Which number in the VIN will indicate what the gears are in the rear end, thank you in advance.
Old Jan 9, 2021 | 10:14 AM
AZSCAWPION's Avatar
AZSCAWPION
None of them. VIN will only spec which engine. For other specifics, you'll want to see warranty tag.
In case of rear gears, can see id tag on rear, count revolutions etc as well.
Old Jan 9, 2021 | 12:32 PM
rm6364's Avatar
rm6364
You'll need the warranty tag on the driver's side door. Go to this website (Decode Your '65-'66 Ford Truck VIN Tag - FORDification.info - The '61-'66 Ford Pickup Resource) and with that information, you will be able to find your gears that were placed at the factory. If they have been changed, then you will count revolutions.
Rick
Rusty Fords
Jul 16, 2020 06:34 PM
Rusty Fords
Apr 27, 2020 10:47 PM
Drew Lear
Large Truck
Feb 27, 2020 10:39 PM
