Help with front end
Old Oct 19, 2003 | 06:55 PM
blue66tang95f150's Avatar
blue66tang95f150
Help with front end
I have I have a 95 f150 and it has a realy bad pop/creek when i give it gas from a stop. It creeks realy bad when I hold the brake and give it gas. I think it is the left control arm. the big bushing is shot and it moved a ton wwhen my bro held the bake andgave it gas. How can i replace thoes is it hard, and how expensive is the bushing. thanks alot.
Old Oct 19, 2003 | 07:33 PM
MustangGT221's Avatar
MustangGT221
On the radius arm you mean? Do a search for radius arm bushing....
Old Oct 19, 2003 | 07:36 PM
blue66tang95f150
yeah that sounds like the one.
Old Oct 20, 2003 | 09:14 AM
walleye96's Avatar
walleye96
One other noise maker on the font suspension for the Fords is a loose lower shock mount bolt and nut . It may seam tight but you need to tighten them good with a air impact wrench.
Old Oct 20, 2003 | 11:07 AM
oldstylefseries's Avatar
oldstylefseries
Hey there,
Been through both of your scenarios. The popping is caused (a lot of times) by the rivets in the frame. When I bought mine new, the rivets were replaced for the same reason you describe. Seems to me there is even a TSB on this.
As for the radius arm bushings, I blew my rivets off with the torch, and dropped the radius arm bracket. Then replaced the bolts with grade 8 bolts (maybe should'a used grade 5; a little bit more flexible). MUCH easier than removing the radius arm itself. Made a big difference in the ride.
Hope this helps,
Tim in Detroit
95 f150 XLT SC 2WD 5.8L
mattymax
Mar 14, 2015 10:40 AM
tackelberry88
1997 - 2003 F150
Jun 16, 2010 08:58 PM
78fordf150ranger
General Diesel Discussion
Dec 27, 2008 06:36 AM
blue66tang95f150
Aug 19, 2003 07:02 PM
witt3696
19
Mar 15, 2002 12:03 PM
