Backup Camera Issue
Old Jul 18, 2020 | 06:16 PM
vans's Avatar
vans
Angry Backup Camera Issue
My new 2020 XLT, Max Trailer has just turned 900 miles, and consequently I have my first problem.
Dam screen goes blank when backing up, at first intermittently, but now it's occasionally working, and of course I just hooked on to a trailer with no camera, that was the final straw
I thought at first maybe something I was doing, but now I think something is messed up, been acting up since the day I drove it home.
Call dealer Monday
Old Jul 19, 2020 | 09:05 AM
GABAR's Avatar
GABAR
Call dealer Monday
Sorry to hear about your problems but, at least you’re under warranty so let your dealer deal with it and don’t stress over it.
Old Jul 19, 2020 | 09:19 AM
JKBrad's Avatar
JKBrad
The first thing I would check is the wiring harness connection to the tailgate. If it’s slightly loose, disconnect, spray with WD40 then reconnect and push it together until it clicks. It’s not uncommon for some harness connections to not be fully seated.
Old Jul 19, 2020 | 02:15 PM
GlueGuy's Avatar
GlueGuy
Instead of WD40 (which not a bad choice), you might instead put in a dab of dielectric grease. My personal favorite is DC4, but there are plenty of good choices at any automotive store.
Old Jul 19, 2020 | 03:35 PM
JKBrad's Avatar
JKBrad
I prefer dielectric grease, but if there is moisture or contamination in the plug, WD40 will clean it out. Just using the grease will seal it in. But let's combine ideas, clean it out with WD40, then use a dab of dielectric grease when snapping it back together.
Old Jul 20, 2020 | 04:31 AM
vans's Avatar
vans
Will do, I have both products, hopefully I'll report back with good news
Thanks
Old Aug 20, 2020 | 03:20 PM
vans's Avatar
vans
Truck is at dealer waiting on new camera, sounds like a lot of 2020's have this issue
Old Sep 18, 2020 | 06:30 AM
brian6674's Avatar
brian6674
My 2020 camera just started to act up. How long did it take them to fix it? Or, how long did you have to wait at the dealer? Are these cameras expensive?
Old Sep 18, 2020 | 07:24 AM
seventyseven250's Avatar
seventyseven250
WD40 is a good cleaner, I have a can of "electrical contact cleaner" that I think is basically the same stuff. If you have real corrosion, one of those cheap "emery board" nail filing boards is a little more abrasive. Most dollar stores sell them. Once it's clean and working good, dielectric grease is a good idea. I have a tube that has lasted me 10 years already, it's handy to have around.
Doesn't sound like the 7-way connector is the issue anyway, I just wanted to throw in my two cents and say I hope your dealer fixes you up quickly.
Old Sep 18, 2020 | 07:54 AM
Kingofwylietx's Avatar
Kingofwylietx
It shouldn't cost you anything since you have a 2020.
The camera is covered by your warranty.
Old Sep 18, 2020 | 08:02 AM
brian6674's Avatar
brian6674
Yes, but if you have to sit at the dealer for three hours to have them fix it, but the camera is $40. I would rather buy the camera and do it myself. Don't look like it would take me 15 min to do.
Old Sep 18, 2020 | 11:44 AM
Kingofwylietx
Agreed. Call your favorite dealer and ask the price to know for sure.
I just skipped through a video of how to do it. It's pretty easy and 10-15 minutes sounds about right if you are using a rechargeable drill to unfasten/fasten the access panel.
The cost for the camera looks to be north of $100, but you'd need to check your dealer. If you know one of the service writers, he 'might' be willing to hand you the camera and let you swap it out there yourself under warranty.
Or, just set an appointment and let them do it. If you are not waiting for anyone elses car to be serviced, they should have you in and out very quickly.
Good luck.
Old Sep 19, 2020 | 08:59 PM
pinstriper's Avatar
pinstriper
I have the same problem, showed up in the first week. Waiting for the part to arrive. This is apparently a VERY common issue.
Old Sep 21, 2020 | 09:22 AM
GABAR's Avatar
GABAR
Sure, you can purchase it yourself and install it yourself but, as annoying as it is waiting at a dealer for any repair, situations like these is why the vehicle has a 3/36K warranty. Also, I really doubt that it’ll take three hours.
With that being said, it’s your money so if you want to purchase a part that’s under warranty and install it yourself, go for it.
Old Sep 30, 2020 | 09:57 AM
pinstriper's Avatar
pinstriper
And it's now an official recall:
https://abcnews.go.com/US/wireStory/...-dark-73336414
