No start / EEC relay related ?
Old Jul 20, 2020 | 08:26 AM
Rkn E's Avatar
Rkn E
Originally Posted by subford
Seems like the head was a 5/16" hex. I used a ground down 1/4" drive 6 point socket.
But all auto part stores sell a tool for those screws.
You might want to watch this video. Its for a newer truck and it has a remote mounted ICM but the PIP works about the same way.
Good video. I was trying to do a similar test with the top wire on the module. I am getting 4V on that wire, and I think he says 4-5V is what the normal value would be.
I guess I am losing connection when I plug the harness in. I will give it a try with something like a T-pin as he did in the video.
Old Jul 20, 2020 | 10:00 AM
subford's Avatar
subford
Note you may want to use a test light with an LED when tracing the PIP circuit.
Attachment 279105
Here is a work sheet and it will be close to what you have.
Attachment 278856/
Old Jul 22, 2020 | 12:51 PM
Rkn E's Avatar
Rkn E
/[/QUOTE]
Thank you very much for the great information provided.
I will pick up a led testlight as you advised and go through the checklist this weekend.
Old Jul 25, 2020 | 09:09 PM
Rkn E's Avatar
Rkn E
Went through the checklist. Looks like a bad ICM.
I ordered a new motorcraft ICM. Looks like distributor needs to come off. Intake manifold is blocking the rear bolt that secures the ICM.
I guess switching the location of the ICM over the fender for later models was a good idea.
Old Jul 26, 2020 | 08:48 AM
jackietreehorn's Avatar
jackietreehorn
Can't you just loosen distributor and rotate it in place until TFI screws are accessible?
Old Jul 27, 2020 | 06:49 AM
Rkn E's Avatar
Rkn E
I actually ended up doing just that. Put a couple marks on the distributor, tried to put it back without messing the timing, but it seems the timing went slightly off. Gotta grab a timing light.
CantAffordAToyota
May 26, 2017 01:43 PM
cedarratt
20
Nov 17, 2006 01:31 PM
jefster
Oct 2, 2004 09:24 AM
nalts
Jun 9, 2003 10:38 PM
noquarter80
Aug 10, 1999 06:24 PM
