1978 - 1996 Big Bronco
rust problems
Old Oct 19, 2003 | 04:30 PM
nelly781's Avatar
nelly781
rust problems
i have a few rust spots on my truck and they arent big, just annoying looking. i thought about sanding the paint down until all the rust is gone and putting painting on some primer until i can get it painted. ive posted on here bout this problem before but i never got to read teh replies. thanks david
Old Oct 19, 2003 | 08:40 PM
89BroncoResto's Avatar
89BroncoResto
That's definately a plan. I'm still doing the bodywork on my 89. What's not done by mid November will get sanded and primed. The only problem with primer is that it holds moisture, and will have to come off to do the job right. Otherwise you'll ruin the new paint job. Good luck.
Old Oct 20, 2003 | 05:28 PM
nelly781's Avatar
nelly781
how have u ben doin body work on ur truck and do u know where i could i find info on wet sanding, basically a more in depth instructional on how to prep my truck for a paint job
Old Oct 20, 2003 | 07:16 PM
BOJOFASO's Avatar
BOJOFASO
it is true that primer is not waterproof but a filler primer is so if you sand and prime use the filler primer so you dont have to remove it when you paint.
