Selecting manual transmission
Old Jul 13, 2020 | 10:54 PM
CJ21's Avatar
CJ21
I have a 1948 F68/F3 that we will put a 302 engine in. I was going automatic but now wish to put a manual tranny in. It will be matched with a Dana 60 axle 3.73 ratio from a 1967 F250. My question to the forum is, what are the best options with respect to torque, durability and ease of installation. Thank you in advance for your advice.
CJ21
Old Jul 13, 2020 | 11:33 PM
EBEAR's Avatar
EBEAR
What are you going to use the truck for ? If you are going to pull heavy loads it may change the answers .
Old Jul 14, 2020 | 09:48 AM
bjmayberry2's Avatar
bjmayberry2
Veteran: National Guard
If you’re just cruising you might look into a T5. That’ll give you overdrive.
Old Jul 14, 2020 | 11:37 AM
CJ21's Avatar
CJ21
Looking for 1/2 ton towing capacity 5-7000 lbs. considering beefing up M5R2 as this was on the Early 90’s 302’s but not sure strong enough?
cj21
Old Jul 14, 2020 | 11:39 AM
CJ21's Avatar
CJ21
M5R2 was on the early 90’s Ford trucks 302. Found one at the wreckers
Old Jul 14, 2020 | 12:34 PM
EBEAR's Avatar
EBEAR
Your choice should also take your HP into consideration . Late seventies to to nineties stock 302 's aren't likely to damage many transmissions but with 373 gears you will want an overdrive if you are planning on much highway travel .
richlars
Oct 17, 2022 08:14 AM
51MHF5
Jul 14, 2013 01:33 PM
Rocketman55
Aug 6, 2009 05:25 PM
dbossman
Jan 26, 2008 05:28 AM
beefcake712
Sep 4, 2006 05:25 PM
