4x4 help
You might be able to see the picture well enough below to suit the need. You can hopefully see you turn the center dial clockwise for Lock and counterclockwise for Free running. You engage the hubs prior to shifting the stick in the truck to either 4H or 4L. 4H is direct 1:1 so the gearing is the same as in 2H. But, 4L is the low range of the Dana 24 and you will find you can pull stumps in this range.
Both of these books go into the rebuilding of the transfer case and the live front axle, but only the 1961 shop manual goes into details about the Warn hubs. You'd want to look at your locking hubs and make sure they have 8 Allen screws holding the hub body like in the picture. That would indicate the original style M4 hubs used from 1959-1965. If yours only have 6 Allen screws they are a newer model. But, I think they look like the older M4 style. Warn was a local company up here in Washington back in the day. They have since moved to Portland.
What is ideal is if the transmission has the mounting bosses on the drivers side for the transfer case shift lever bracket. Would look sort of like this picture below. But there are ways to fab something up for that, too.
