Rooftop A/C
Old Jul 13, 2020 | 01:32 PM
stm76's Avatar
stm76
Rooftop A/C
I know that there was a rooftop A/C unit as a possible upgrade or add-on for the 61-67 Econoline's. Has anyone actually ever seen one? I would love to get my hands on one, but realistically, I'll need to install A/C differently. Maybe put the evaporator on top of the doghouse? I have the 170 engine. What are your thoughts on it being able to handle the extra load of A/C?
Or, if you have other A/C kits that work well, I'd love to see recommendations.
Old Jul 14, 2020 | 07:22 PM
EmilBarnabas's Avatar
EmilBarnabas
See here: Econoline Air Conditioning
Old Jul 28, 2020 | 08:01 AM
Ultrapilot's Avatar
Ultrapilot
I live in Fla. so A/C was a must! I have 1961 with a 64' 200CID. I bought an under dash unit from coldmasterinc.com $600 and the compressor/alternator bracket from nostalgicac.com $152.00.
I mounted the fan and condensor in front of my radiator (plenty of room). I had to make my own brackets to attach to the sides but I used some aluminum 1" x 1/8" (Home D) and bent it to fit and drilled the holes for screws. I had to change the alternator to the Denso mini types that puts out about 100A. Got it from a generator.starter overhaul shop for $100. (the old alternator is too large to fit and be able to adjust the belt tension). Some experimenting with fan belt length, modifying the bracket a little and for a total investment of less than $900 I got A/C. I tinted my windows and insulated my doghouse.
Old Aug 2, 2020 | 10:01 PM
stm76's Avatar
stm76
Thanks for the info. I think I may try for that route and forget the roof mount option. Any idea which Denso you ended up with so I can go searching?
Old Aug 3, 2020 | 01:19 PM
Ultrapilot's Avatar
Ultrapilot
Denso Alternator
The Denso alternators are all the same size case so I just bought a rebuilt one from an a starter/alternator shop that put out 100A and had them swap out the pulley for the one I had on my old alternator..If you Google Denso Mini Alternator you will see they are the same size with different Amperage outputs. Look for around 90-120A that will handle everything I then fabricated my own bracket and secured it to the bolt head that sticks up near the water pump housing/Valve Cover. I can take a photo and send it if you want. If you are still using a generator, you can get rid of it and the voltage regulator as the Denso is a one wire hookup. You will need the mini alternator or you won't be able to adjust the belt tension as the old alternator will be right against the doghouse. Your compressor will go on that special bracket (nostalgicac.com) where your old alternator used to be. I had to cut off a few inches of the bracket "legs" to get it to fit. It took a bit of work to get it all to fit but it's definitely do-able.
Old Aug 3, 2020 | 07:11 PM
stm76's Avatar
stm76
I'd love some pics. It is 104 today, so AC is becoming a necessity.
Old Aug 6, 2020 | 05:27 PM
Ultrapilot's Avatar
Ultrapilot
Photos
Looking down at the alternator and handmade bracket
Another view
Looking down at condenser and 12V fan in front of the radiator
condenser, fan and dryer (hoses connect to the dryer.
Two ***** to left of grill are the fan speed/ON/OFF and Temp. Silver **** to upper left of these ***** is the heater control.
Old Aug 10, 2020 | 12:58 PM
stm76's Avatar
stm76
So, are you using an electric compressor instead of one that connects to the belt? Is that the reason for the 100A alternator? Or is the compressor under the alternator? It looks like it may be the thing up in the very front of the doghouse.
Old Aug 10, 2020 | 03:12 PM
Ultrapilot's Avatar
Ultrapilot
I am using aN SD508 Sanden Style V-Belt 2 Grooves Pulley 3/4" 7/8" Ports For SD508 Sanden Style V-Belt 2 Grooves Pulley 3/4" 7/8" Ports. Comes in the kit. It’s located underneath the alternator on that bracket that you buy from nostalgia. It’s hard to see because it’s under the alternator. I recommend a 70–100 amp alternator. The compressor is pulling 5 A and electric fans pulling a few.I think the stock alternator or generator or whatever it is you have is probably not big enough to handle all the loads. Cost wise it doesn’t matter the price is essentially the same so why not buy the bigger amperage and have enough for the future in case you install stereos lighting etc.
Old Sep 3, 2020 | 05:43 PM
stm76's Avatar
stm76
@Ultrapilot Does this look like the correct bracket? I have the 170 engine, so I'm thinking this is it. It appears to come with mounting bracket for both the compressor and alternator.
https://nostalgicac.com/mount-kits-p...ford-6cyl.html
Also, I have an alternator place checking to see if they have a Denso they can sell me. Thanks for all the info. This will definitely help me.
Old Sep 4, 2020 | 12:56 AM
Ultrapilot's Avatar
Ultrapilot
y
yes that is the correct bracket!
Old Jun 11, 2026 | 07:51 AM
theoneandonlyjonasv's Avatar
theoneandonlyjonasv
Sorry for resurrecting an old thread: @Ultrapilot - did you have any overheating issues with the condenser mounted in front of your radiator in the doghouse with this setup? I'm asking because I'm about to install my electric a/c kit and wanted to mount my condenser the same way with my 240 engine.
Old Jun 11, 2026 | 11:58 AM
tjc transport's Avatar
tjc transport
i ain't rite
he has not logged on since september of 2020
Old Jun 11, 2026 | 01:17 PM
theoneandonlyjonasv
Was holding out hope.
Kyle Wood
Michigan Chapter
19
Oct 31, 2016 09:31 AM
Tecman
Jan 30, 2009 09:19 PM
dnorris80
2004 - 2008 F150
Feb 21, 2008 10:09 AM
idbl_fanatic
May 2, 2007 09:40 AM
