Suddenly stumbling
Old Jul 13, 2020 | 11:07 AM
RGAllen1960's Avatar
RGAllen1960
Suddenly stumbling
Scratching my head with this. My '84 F150, 351W Truck has run great since I bought it nearly two years ago. Always starts right up. Couple of days ago after about 15-20 minutes of driving, she started stumbling. When I took off from a stop, the stumbling is really bad. What puzzles me is that last night I went for drive and it didn't stumble at all. This morning I drove to the grocery store about 10 miles down the road. She ran perfect, but right out gate heading out of the parking lot the stumbling started again. I was thinking maybe bad gas. this all started shortly after I filled up the main tank the other day, but today I switched to my saddle tank, which I didn't put any gas in the last fill up and it still stumbled. Anyone come across this issue?
Thanks in advance.
Old Jul 13, 2020 | 04:54 PM
Franklin2's Avatar
Franklin2
Cruising ok? Only does it when you press the gas and demand more from the engine? Is this the 4bbl engine? Completely stock?
Old Jul 13, 2020 | 05:42 PM
RGAllen1960
Once the hesitation starts, I can still feel it stumbling, even when cruising. It is a four barrel , stock intake with an Edelbrock 1406. All the emissions stuff had been removed when I bought it. When I bought it, it had a Holley 4180, but it had a blown power valve, so I put a new Edelbrock on it. Never had an issue. I'm gonna go through it tomorrow and check the plugs, wires, cap and rotor..etc
Old Jul 14, 2020 | 03:04 AM
BigBlue2's Avatar
BigBlue2
What kind of exhaust system do you have? Do you have a catalytic converter? Dual wall exhaust pipes?
From your description of the issue it seems your motor runs strong from cold to warming up but after the motor has been at operating temperatures for 10 or 20 miles the stumbling begins. This indicates that your fuel and ignition are working properly.
Sometimes as the exhaust system heats up portions of the inner wall of dual wall exhaust pipes can collapse blocking or partially blocking the exhaust flow. This will produce a loss of power. Could also be a heat induced issue in the cat or the muffler.
Old Jul 14, 2020 | 07:14 AM
FuzzFace2's Avatar
FuzzFace2
If you got bad gas, water, it could still be in the carb bowl when you switched tanks.
Dave ----
Old Jul 14, 2020 | 07:22 PM
BigBlue2's Avatar
BigBlue2
Another reason I thought of a collapsed dual wall exhaust pipe was that it ran fine going to the store. Then presumably you spent enough time shopping that it cooled down some. The heating and then cooling can contribute to the collapsed exhaust. It's hard to check the back pressure but can be done. If your exhaust pipes are old dual wall have a muffler shop put on some oversize single wall pipes and let that v8 breathe.
Old Jul 14, 2020 | 09:34 PM
86bull's Avatar
86bull
Have you replaced the fuel filter?
I've had a similar situation. Once I thought about what was happening and when.
I realized when it was sitting, all the seidament in the tank was dropping to the bottom. When I drove it that seidament was getting stirred up. The filter was only allowing a little gas through it.
I replaced the filter and the problem went away.
Later I dropped the tank to find out it was full of rust.
Old Jul 15, 2020 | 02:56 AM
BlueWhiteFord's Avatar
BlueWhiteFord
Same for me. My carb bowl was also filled halfway with really fine rust particles. I never checked the gas tanks when I bought it, and it bit me.
Old Jul 15, 2020 | 09:35 AM
RGAllen1960
The filter is fairly new. I think that I did figure out the problem. It's so simple,but it didn't cross my mind until today. the engine is misfiring, so it has to be the coil. That"s the one simple thing that I have failed to replace since I purchased the truck. I'll get back to ya'll on that. Thanks for the input.
Old Jul 15, 2020 | 11:45 AM
kr98664's Avatar
kr98664
Is the idle okay? Does the engine only act up above that?
If so, my hunch is a leak in the vacuum advance system, either in the line or the bellows itself. Vacuum for this system is typically taken from a port just above the throttle plate. This means there's no vacuum present at idle, so you only get the leak and lean condition above that.
If the vacuum advance isn't working (for any reason), you may not even notice it. But if a vacuum leak is present, that can cause poor running. It's easy to test. Disconnect the line from the carb and put a cap on the carb fitting. Go for a short test drive. If the engine runs okay now, you have a vacuum leak in the advance system.
78Ranger_GARedNeck
24
May 6, 2008 08:30 AM
enominus
Jun 9, 2007 05:43 AM
longbowdude
1997 - 2003 F150
Aug 11, 2006 09:22 PM
Ogriv
May 25, 2006 11:23 AM
shanesF150
May 6, 2005 09:25 PM
