Leveling kits/spacers
Old Jul 12, 2020 | 10:10 PM
FordGuy110's Avatar
FordGuy110
So Just to confirm and clarify, since the 2020s sit lower in the front by an inch, if I install a 2.5” spacer I’ll still be an inch lower than a 2017-2019 with the same space installed?
if so, then I’ll want a 3.5” spacer right?
Im trying to decide on rims/tires if I want to run 37s or not. The rims are 20x9 +0 offset.
i believe going to a 35” tire from the stock 275/65/20 will raise the truck 1/2” and a 37 would be 1”.
Old Jul 12, 2020 | 10:26 PM
SpruceWillis2020's Avatar
SpruceWillis2020
You're correct on the overall front height.. 2020s are also 1-1.25" lower in the rear with the smaller block.. were you intending on doin a larger block also? If not the front would b angled upward a bit.. but just from what I've read on here, staying at that +0 to +20 offset range will give u a much better chance at runnin those 37s.. So u should b good with those when u settle on a level
Old Jul 12, 2020 | 10:38 PM
FordGuy110's Avatar
FordGuy110
I’m looking at 3.5” in the front which comes with a 4” block which would raise the rear 1 inch. I would buy a 5” block to raise it 2”.
Old Jul 13, 2020 | 07:53 AM
SpruceWillis2020
https://www.ford-trucks.com/forums/w....php?t=1616773
Ok that'll b a nice setup.. Here's a little more feedback.. this guy has much more offset and had to trim a tad.. But the pics will give u a good idea of the look
rtazz17
Sep 24, 2009 08:48 PM
wyo_driver4
Apr 27, 2007 03:39 PM
alexisdakota
2004 - 2008 F150
30
Jun 8, 2006 06:04 AM
JP33
2004 - 2008 F150
Dec 26, 2005 04:23 PM
99stroke
Sep 2, 2003 10:41 AM
