BACKUP SENSORS WACKY
Old Jul 12, 2020 | 01:06 AM
Rainmaker1's Avatar
Rainmaker1
I hope someone has a good solution for my problem with LED back-up lights. Bulbs are from V-Leds (V6 EXTREME Reverse Light), and added the license plate light (LPR LED Back Up Light). Since adding the LPR, my reverse sensors beep intermittently when in reverse. They should be silent until they detect something in range, they should beep steadily, then increase frequency as they get closer to the object. They do operate properly when I'm ~14" from the object they sound continuous. I could live with the irattic beeping but I would like them to operate properly. Can anyone who understands LED's and electrical tell me if there is a fix?
Here is what I have. And if anyone wants to know, yes they are very bright!
https://www.vleds.com/shop-applicati...it-w-3156.html
https://www.vleds.com/shop-applicati...erse-72-w.html
Old Jul 13, 2020 | 03:06 PM
2002Ex's Avatar
2002Ex
Look into a load equalizer. The reverse sensors might require a certain load on the circuit to function correctly. If you reinstall standard bulbs and it goes back to normal, then the LEDS are the issue.
Socal82bronco
Electrical Systems/Wiring
Feb 9, 2014 07:23 AM
Big.blue0586
Jan 16, 2013 07:32 AM
Superduty.pride
Oct 21, 2011 12:10 PM
rkmarine
Jun 17, 2006 10:14 AM
chopper269
May 3, 2006 09:46 PM
