Cargo Lights
Old Jul 11, 2020 | 08:12 AM
Tom Childers's Avatar
Tom Childers
Question Cargo Lights
The truck bed lights constantly turn on and off by
themselves when engine isn't on. When the engine
is turned on they stop flashing and work normally.
Shut the engine back down and they start flashing
again. This went on for about 4 hours and now
they work perfectly fine as if there was no problem.
What could cause that? Do not have a bed switch
Old Jul 11, 2020 | 02:05 PM
Robbgt's Avatar
Robbgt
Welcome to the forums.
If you don't have a bed switch how are they activated? Sounds like they are not stock - may be ringing out to see where they get power and ground from.
Old Jul 11, 2020 | 07:38 PM
Tom Childers
I should have been more specific its the lights on the cab on each side of the 3rd brake light, and now the hazard lights are coming on by themselves also
Old Jul 12, 2020 | 09:13 PM
Lone Wolff's Avatar
Lone Wolff
Maybe a door switch? Those lights typically come on each time a door is opened, then go off when the door is closed, correct? Maybe the switch is going bad causing the circuit to think the door is being repeatedly opened then closed?
Old Jul 13, 2020 | 08:21 AM
Tom Childers
thanks, someone told me that on another post, and to spray them with wd 40 tried that, will be looking into finding short today.
ShaneKC
2009 - 2014 F150
May 6, 2020 08:32 PM
JH250
Nov 11, 2019 07:23 PM
lambchops25
1997 - 2003 F150
Jul 31, 2019 03:58 PM
VONxRUBENxLA
Feb 2, 2012 11:18 AM
Bookman
13
Mar 16, 2009 11:00 PM
