a/c expansion valve
Old Jul 9, 2020 | 08:56 AM
raye321's Avatar
raye321
a/c expansion valve
Good advice. Since I am installing a new line from the condenser to the expansion valve I'm going to replace the valve as well. I put the valve in about 6 years ago. The coiled part of the valve is clamped against the low side pipe going into the evaporator box. I used some sort of flexible material to pack around the coil and pipe then foam and duct tape over it. The flexible material should be replaced. What is used to pack around the coil and pipe?
Is it a good idea to use thread seal tape around the fitting connections?
hdman6
6.7L Power Stroke Diesel
22
Jan 12, 2020 03:47 PM
BonebrakeJones
Jan 2, 2006 12:10 AM
GendoIkari69
Exhaust Systems
Sep 20, 2001 06:25 PM
