Blackstone Testing
Old Jul 4, 2020 | 06:53 PM
TTXDavid's Avatar
TTXDavid
Blackstone Testing
Has anyone tested their oil in their 6.7 multiple times based on mileage differences between changes?
I am a little surprised Ford recommends only 5,000 miles between changes. I am going to go off of the monitor recommendations but only have 3100 miles so far and did an early change initially around 1600 or so (seeing its a $10.5k upgrade, why not on break in...).
Having run lots of Amsoil over the years, and done extended intervals, the idea of 5,000 miles changes seems premature. The 6.7 is a whole other animal , so I am looking for some data if anyone has some?
Thank you in advance.
Old Jul 4, 2020 | 08:33 PM
samuse's Avatar
samuse
Run Motorcraft oil and change it every 5K or when the IOLM says.
You really can’t do anything better.
Running the same oil for 20K+ doing the samples, changing the filter anyway is a bunch of nonsense.
To me it’s like cleaning and reusing disposable diapers. You’re spending more time and money to save what??
Old Jul 4, 2020 | 10:25 PM
Lamoon78's Avatar
Lamoon78
I do the 5,000 dont care what the little computer says. They want you to go by that stupid thing not me. I do the extreme change interval need to read that part cause most anybody is going to fall under it. I think that would come into play on a warranty issue.
Old Jul 4, 2020 | 11:39 PM
ford390gashog's Avatar
ford390gashog
Use ALS labs cheaper and faster than Blackstone plus they give you the TBN at no extra cost. Plus the kits are 15.00 at NAPA and 7.50 during the filter sale.
Old Jul 5, 2020 | 11:34 AM
TTXDavid's Avatar
TTXDavid
Thank you for all the feedback. I will try out ALS labs. If the ford motorcraft synth blend is still well within performance at 5k miles, I will start going up in 1k mile increments to see how it does to find the sweet spot . If the economics are worth it I may switch to higher mileage interval oil. The tough part is that I keep pretty busy so paying someone to put in Amsoil
or similar may not be worth it. That and I need to verify the oil I would be using outside of the Ford stuff has the new standard additive requirements listed as I saw in another thread while doing my research.
We’ll see what happens and I will post results and update the thread over time. That or start a new thread to track oil performance.
Old Jul 5, 2020 | 01:40 PM
senix's Avatar
senix
So how well can dino oil perform?
This is my truck with dino M/C 15-40WT. all towing miles,
While good I would not push the miles higher
Fordfreak1978
General Diesel Discussion
Oct 10, 2021 11:38 AM
ttavasc
Mar 29, 2019 09:30 AM
fnx4wheeler
Oil & Lubrication
15
May 8, 2005 04:36 PM
carpe_diem
Oil & Lubrication
Jul 13, 2003 02:18 AM
