Sponsored by: Real Truck
No axle code on door build sticker
Old Jul 1, 2020 | 12:56 PM
dknierim's Avatar
dknierim
Hi,
I just bought a 2000 F-250. The build sticker on the door jamb has no entry for axle code. Is there a default value if nothing is specified? The metal tags on the rear diff also have nothing about ratio on them. Is there any other way to figure out what I have without taking the cover off??
thanks for any feedback!
Old Jul 1, 2020 | 12:57 PM
ford390gashog's Avatar
ford390gashog
The metal tag should have the ratio. Would look like 3L55 if a 3.55 Limited slip as an example.
Old Jul 1, 2020 | 02:46 PM
Desert Don's Avatar
Desert Don
OR, if there is nothing else, jack up the rear end, put on jack stands, put truck in neutral, put a mark on one tire wher you can see it from under the truck, put a mark on the drive shaft.
Now then rotate the drive shaft until the tire makes one revolution, counting the rev’s of the D.S.
3 1/3 rev’s of D.S. To 1 rev of the tire = 3.31
3 1/2 rev’s = 3.55
3 3/4 rev’s = 3.,73
4.1 rev’s = 4.10
4 1/3 = 4.30
4 1/2 = 4.56
And so on
Old Oct 4, 2020 | 08:40 PM
dknierim's Avatar
dknierim
Thanks for all the feedback!
This weekend I changed the oil in my rear axle. It turns out the metal tag DID have the ratio on it, but the bolt hid the "3" at the beginning.
Note to self: Remove the metal tags and get good light on them so you can see what you are looking it! It does not hurt to buff the tags to be able to see everything.
EZFEED
1997 - 2003 F150
Jul 29, 2011 06:10 PM
Max1
1983 - 2012 Ranger & B-Series
Jan 8, 2005 10:28 AM
lebrund
All Things Towing
Sep 28, 2004 06:26 PM
SPODEBOY
Nov 11, 2003 10:12 AM
5_labsownus
May 2, 2002 07:30 PM
