1978 - 1996 Big Bronco
Which Engine?
Old Oct 18, 2003 | 11:20 PM
Demon345's Avatar
Demon345
Which Engine?
How can I check If I have a an M or a Winsor, I have a 1989 but the guy I bought it from said its a winsor, I dont know anymore
Old Oct 19, 2003 | 12:00 AM
gilraine's Avatar
gilraine
it's a windsor.. the M's went away in like 82
Old Oct 19, 2003 | 12:41 AM
Demon345's Avatar
Demon345
but how can you check
Old Oct 19, 2003 | 01:45 AM
Capone's Avatar
Capone
Look at the valve covers, the W has 6 bolts, the C has 8....
look at the thermostat housing...the W is mounted on the intake...the C is mounted on the block....
Then look at the heads, the W's are narrower....the C's are huge...
The C engines were dropped in the early 80's.
Old Oct 19, 2003 | 05:08 PM
1pump's Avatar
1pump
The fastest way would be just one glance under the hood.
There's no such thing as a 351M or 351C with EFI.
