Sponsored by: Real Truck
FALSE OVERHEATING
Old Jun 29, 2020 | 09:40 PM
Txboy1981's Avatar
Txboy1981
FALSE OVERHEATING
False overheating....pulling a load temp gauge will peg out....reduced engine power warning....I can push clutch in and turn key off count to 10 turn key back on and everything is back to normal. I’ve changed thermostats and temp sensor.
Ready to park truck and walk away. I NEED HELP
2008 F-350 dually.....6.4 powerstroke
Old Jun 30, 2020 | 05:16 AM
senix's Avatar
senix
what codes do you get if you scan it?
Old Jun 30, 2020 | 05:31 AM
EDC8008's Avatar
EDC8008
If it indicates overheating it is most likely overheating. Shutting it off and restarting sounds like it is just clearing the issue temporarily.
How did you refill the cooling system and did you ensure all the air was out of the system. If not trapped air will do this.
Best way is use the vacuum system and pull a vacuum on the cooling system and use that to fill. That's what I did and never had an issue. I don't know who might rent one but worth checking at different parts store.
Old Jun 30, 2020 | 05:34 AM
senix's Avatar
senix
probably autozone or others may rent it.
Old Jun 30, 2020 | 05:43 AM
EDC8008's Avatar
EDC8008
What I was thinking, maybe O'Riely's also. I bought one for my own use, works great on my 6.7 in the truck and for my Bronco, I quit having issues with it also since I started using it.
Old Jun 30, 2020 | 10:15 AM
redford's Avatar
redford
FTE Leadership Emeritus
Have you made sure there isn't any air trapped behind the thermostat?
Also, check your engine grounding straps and the overall health of your battery charging system.
Old Jun 30, 2020 | 08:48 PM
99f350sd's Avatar
99f350sd
Head gasket issue. Very common shut off and the air block disappears and good for a while. Check for gasses in radiator....Hope not!!
Old Jul 1, 2020 | 05:06 AM
senix's Avatar
senix
6.4 is not known to blow the headgaskets such as the 6.0 unless you were tuned and towing over stock rated HP.
bubbco
6.7L Power Stroke Diesel
Apr 20, 2015 12:17 PM
wresleu
1997 - 2003 F150
Sep 6, 2009 03:58 AM
dad2074
2004 - 2008 F150
Jan 29, 2009 05:05 AM
