click click click
glow plug controller started cliccking imediately. I don't know
nuttin about diesel. This is the first one I have ever worked on.
I have a book that tells me how to test the glow plugs, wiring
harness and controll modual. I have not done that yet. I feel like I might have some wire connected up to the wrong place. Is the clicking noise normal. Any suggestions on what to look for?
Charles
I just installed a rebuilt 7.3 non turbo diesel engine in my daughters F250 Ford pick-up. When I turned the key on the
Charles [/QUOTE
that is normal your diesel truck is ready to fire up after you hear those clicks, that mean you glow plug relay is working,
when you don;t hear those clicks they you got a problem, hope that answer your question,
if you have any more question post it on the website, some one will answer your question, their is lot smart diesel truck owner willing to help you out.
good luck.
When one of you told me some clicking was normal I continued like I knew what I was doing. We found both batteries low. Charged one and replaced the other. Turned on key and had short click click click. Then everything worked like I expected it should. The new engine started after about 1 minute of cranking and has been working great ever since. I bought this engine from Jasper engines out of Indiana. Their service has been great.
quick delivery, through explination of what I would recieve and good follow-up when I called for help Saturday. Only complaint is that the drain plugs were all left open from the factory and I lost some antifreeze. One bolt was loose by the thermostat and that gave me a small leak. Other tan that everthing went well. Beautiful engine. If I ever need another I know where to go.
