My front turn signal got damaged and I got some replacements for it. The only problem is there is no instructions and I cannot get the turn signal out of there. I cannot get the pannel that they sit in off either. Thanks for the input
im not sure if your turn signals are the same as mine but there is a hex screw that holds the lens in there.they are on a track that slides out towards the bumper.remove the hex screw that is located under the hood behind the headlight,then give the lens a lil wiggle and it should slide out towards the bumper.good luck
Originally posted by black98f150 im not sure if your turn signals are the same as mine but there is a hex screw that holds the lens in there.they are on a track that slides out towards the bumper.remove the hex screw that is located under the hood behind the headlight,then give the lens a lil wiggle and it should slide out towards the bumper.good luck
What year is your truck? I cannot find the hex screw that your talking about..
