55 F100 New Mexico Project
#151
on
It seems like allot of redundant work to put it in and take it out again but of course it's your time . How is the oil pressure - consumption , how hard do you drive it ? If it was me and the oil consumption isn't too outrageous ( will be better with the leak fixed ) I would do the bearings , timing chain , oil pump and rear main seal for peace of mind . If your intentions are to do a complete rebuild later the keep an eye on and ear out for any knocking and stop using it if there are issues . It's allot tougher to rebuild a block that has a rod sticking through it . lol JMHO
#152
#153
Be sure and check the main or rod journals in case they have been turned.
#157
on
Bearings -- Not real good condition, but evenly worn. How is the thrust surface? What do the rod bearings look like?
Chain -- needs to be replaced
FP - Need to pull the pump or front cover to see why it doesn't sit right
The overall question is -- do you really want to put this back in the truck and go to all the trouble of yanking it in a year? It's a lot of work just to get it back out of a fully assembled truck. Why wait?
On the plus side, the engine looks clean inside.
The FP is for the bin anyway. I can see that the FP rod is out of whack (bent? loose?) I'll pull it and toss it. Not sure a diagnosis is worth while, unless you guys are curious or that pump is rare (glass bowl).
I'll pull a few more bearing caps and check that thrust bearing.
#158
on
These #2's are actually matched. Here is a blow up of the original image.
But, your point is a good one. I'll go check all the numbers as I look at more of the bearings.
See my previous post replying to Ross as well.
#159
#160
I like smooth and even. Good bit of wear... not so much. Everything on this truck has shown " a good bit of wear". Seems like, from trucks perspective I bought it just in time. The PO's son, not a car guy, said he was tempted to drive the heck out it.
That's good that #2 are matched. The rod looked to be a 5 to me, but she, and needing new glasses made the rod look like a 5.
I completely understand not wanting to spend time and money on the engine now. But.....the mains need to be changed, and I would think the rod bearings are worn as much, or more.
The timing chain and gear are worn to the point of ready to fail. The chain is almost against the block it's so loose.
If nothing else, put in new rod and main bearings, and a timing gear set. You have the engine open. There will never be a better time. I wouldn't trust the timing gears and chain 100 miles.
Amazon has some very good prices on no-name bearings and such. Probably can find a timing set for your engine too.
At least do these even if you don't do the oil pump. Are you ever going to enjoy driving something you expect to quit running any minute?
If you have to let the truck sit a while, you will be ahead doing the bottom end and timing.
Your engine is very clean inside. Don't risk it over 3 to 4 hundred dollars. If it's not going to be a high mileage daily driver, I would leave the top end alone.
#161
on
I pulled the center main with the thrust bearing surface. The wear is similar to the other main in the previous post. Marking on the back is shown one of the photos below. It is a Federal Mogul "Fm" bearing with no stamp indicating undersize.
I also pulled a rod cap. This shows nothing like the wear of the mains. The bearing is from Clevite. Again, no clear indication of undersize.
marking are.
CLEVITE 77 on one end
1173 010
CB 461P on the other
it is possible that "010" is an undersizing but this far from clear
This video explains Clevite markings:
So, perhaps the crank has not been ground at all? And the rod is either standard or 0.010 under ? Or we just don't know.
Photos:
center main, side 1
center main side 2
Markings
center main crank
the rod cap
the rod crank
Question:
Yardbird: when you say just do the bottom end, I had not considered that possibility. What does that entail? I see two answers (A and B below) but I'd love to hear what you had in mind.
(A) Leave the heads in place and don't even look at the bores? Cam stays in place?
(B) Pull the heads but don't do any work on them? Pull pistons and measure the bores for taper and either hone or bore as needed? Then it's new rings, at least. This is basically a complete short-block rebuild
I really appreciate both of you letting me benefit from you experience.
#162
At this point it wouldn't take much to take the crank out, take it to a machine shop to have it mic'd and polished, and a correct set of sized bearings (rods and mains) purchased for install. That would end speculation, take care of the bottom end once and for all, and it wouldn't break the bank. It would also give you the opportunity to address the rear main seal correctly, which is what started this whole adventure.
You can see the bottoms of the cylinder bores. What do they look like? Can you still see cross hatch marks in the bores, or are they all worn looking where you can see the trail of the pistons in the walls? That could tell you something about cylinder wear. Did you have it running prior to tear down? Did you ever do a compression check?
#163
on
...Late 50s or early 60s 292 from a manual tranny sedan or wagon of some sort ("EDB-E" block, front oil pan reservoir, crankcase vent up top at the rear of the valley pan.)
...It ran like a champ before I took the truck apart to get at the cracked frame.
...Vacuum at idle was rock steady at 17.5 in-Hg (I live at a touch above 5000 ft altitude so this is quite good.)
...Plugs 1,2 and 7 have "non-fouling inserts" on the spark plugs, suggestive of some oil control problem but no info on the "what" and "when" of this.
...I did not get around to doing compression tests before I reset the project to address the frame. (Regretting this.)
...I have no information on consumption of oil, only know that it dripped. I ran the motor only about 2 hrs before dissembly of the truck.
...Has the external oiling lines feeding into the rocker covers.
I am settling in to do AT LEAST what you say, all new bearings on crank and rods, new timing chain, oil seals. I believe this is what Yardbird has in mind as well. I am still debating with myself as to how far to take the rebuild. I mentioned the non-fouling inserts on 3 cylinders to prompt experienced folk such as you to suggest what nefarious goings on might be happening in the heads. (Trashed valve guide seals? Bad oil rings? ) On the other hand, maybe back in the day folks just put those inserts on as soon as a plug fouled. (see above, regret lack of compression test.)
#164
The good news is it's pretty easy, relatively speaking, to do head work later if the need arises down the road. If it ran good before I'd be less inclined to go any deeper than discussed at this point. Mission creep is a terrible and expensive thing.
I'm going to speculate the numbers on your rod bearings 11 73 010 are a date code, 11/73, and an undersize ID 010. The CB 431P is a part number.
https://www.summitracing.com/parts/c...SABEgKOhfD_BwE
#165
