help im freezing
Old Oct 18, 2003 | 06:11 PM
max82's Avatar
max82
help im freezing
i have a 1995 ex eddie bauer with the electronic climate control. Since yesterday i cant get heat out of it. i check the heater radiator hoses and they were hot so it cant be the thermostat. It gets colder when i put the ac on. Maybe its a vacuum problem? i really have no idea. Also sometimes its the opposite its stays hot even when i put it to 15 degrees. help would be greatly appreciated. thanks
Old Oct 18, 2003 | 08:38 PM
michaeld6638's Avatar
michaeld6638
sounds like your blend door is sticking. There are instructions about fixing the blend door although I don't remember if it applies to 1995 models or not.
Old Oct 18, 2003 | 09:49 PM
c96drumm's Avatar
c96drumm
Usually when the blend door breaks, you get nothing BUT hot air. My 96 has a vacuum operated heater control valve in the heater hose under the hood on the right side just forward of the firewall. I would look at that first.
Like your signature, michaeld6638!
