LED lighting
Old Oct 18, 2003 | 04:49 PM
clean79150's Avatar
clean79150
LED lighting
Anybody know if any company makes an L.E.D. (light emitting diode) tail-light kit for our old Fords?
Old Oct 18, 2003 | 09:03 PM
theonlybull's Avatar
theonlybull
i think the hot rod mag's have LED bulbs that will replace standard 1157 & 1156 bulbs
Old Oct 18, 2003 | 09:11 PM
Torque1st's Avatar
Torque1st
Posting Legend
Bull is correct, you can also get them at any truck stop, many auto parts stores, ebay, and at truck parts web sites.
I plan on converting everything that I can over to LED lights on my truck.
There are some posts here on clear lenses also you can check out. Also some dash light conversions.
LED = Light Emitting Diode
DED = Darkness Emitting Diode
FED = Flame Emitting Diode
SED = Smoke Emitting Diode
PED = Plasma Emitting Diode
Old Oct 18, 2003 | 10:09 PM
clean79150's Avatar
clean79150
Thanks for the replies, I've only seen them on tractor trailers and such, I'll have to check the parts store for them.
Old Oct 19, 2003 | 12:08 AM
LxMan1's Avatar
LxMan1
These are just the bulbs, you still use the stock lenses.
Jimmy
Old Oct 19, 2003 | 01:07 AM
Crumm's Avatar
Crumm
I wish I had some digital photo's of a 74' I use to have but they are all on paper. I will try to remember to get them scanned one of these days but for now I will try to explain.
The tail lights on the 73-79 trucks are very flat. What I did was remove the tail light and use it for a pattern. I cut out a piece of 1/8" steel in the proper shape and drilled holes in the top and bottom for mounting. I then made some spacers so that it would fit flush with the body when mounted in the tail light hole. Next I cut out the center of the 1/8" plate to fit a oblong sealed beam truck-lite. I also drilled a 2" hole in the bottom for a 2" clear sealed beam truck-lite to be used as a back-up light for a finished look. This was back in 1993 so the LED's were not yet available but they are now in the same size lighting.
The other option is to just get some LED bulbs like the others stated above.
Old Oct 19, 2003 | 01:15 AM
Crumm's Avatar
Crumm
The lights I am talking about can be seen HERE .
Old Oct 19, 2003 | 06:25 AM
theonlybull
their nice lights crumm, even the non-Led ones are really bright, that's what i used when i build the steel body on my 79. you can see them in my gallery
Old Oct 19, 2003 | 07:34 AM
blueoval78's Avatar
blueoval78
on that show trucks the other day, he had a plug in LED light bulb for the rear. but it was a flat panel that mounted to the light cup, in between the lense, it was much bigger contaning much more LED bulbs, i was hoping to come across those for these trucks
Old Oct 19, 2003 | 07:47 AM
blueoval78's Avatar
blueoval78
heres the link to what i am talking about, excuse the fact that its a chebby, i cant find them for ford yet
http://www.earlyclassic.com/ledtaillights.html
Old Oct 19, 2003 | 02:13 PM
johnraym's Avatar
johnraym
led
Try WWW.ledtronics.com
Old Oct 22, 2003 | 05:25 PM
Alphy's's Avatar
Alphy's
PEP Boys carry a direct replacement bulb for the tail lights, and are reasonable priced.
