No Crank No Start
Old Jun 16, 2020 | 03:43 PM
K Scemi's Avatar
K Scemi
Exclamation No Crank No Start
The Other day I was at a stop light and the engine turned off and all the lights came back on if you were getting ready to start the vehicle again, but nothing happens when the key is turned. I have replaced the ignition switch, all fuses and relays checked, and replaced the battery (needed it anyway) and still the same-thing. I have a 2004 5.4L Expedition Eddie Bauer, any thoughts?
Old Jun 17, 2020 | 10:57 AM
alloro's Avatar
alloro
Did you try starting it in neutral or just park?
Old Jun 17, 2020 | 02:23 PM
K Scemi's Avatar
K Scemi
Yes I did still a no go
Old Jun 17, 2020 | 04:36 PM
projectSHO89's Avatar
projectSHO89
What is the status of the THEFT and CHECK ENGINE lights when the ignition switch is turned from OFF to RUN? Same for odometer display?
Old Jun 17, 2020 | 05:01 PM
K Scemi's Avatar
K Scemi
Old Jun 17, 2020 | 07:40 PM
z31freakify's Avatar
z31freakify
  • Check and see if the PCM connector isn't unplugged or loose.
Old Jun 17, 2020 | 09:36 PM
projectSHO89
Insufficient detail provided, but it appears that the PCM and the cluster did not power up together and establish their synchronization within the allotted timing window. Multiple possible causes but a failing PCM Power Relay is one of the more common failures.
Tgroves1213
Apr 25, 2020 07:34 PM
Sean11
2004 - 2008 F150
13
May 7, 2019 12:27 PM
mkts17
Apr 27, 2018 07:47 PM
dkhender
Jun 8, 2009 08:57 PM
grip1968
Nov 14, 2006 12:46 AM
