acid dipping parts
on
1 Post
<cr>
I've had one car sandblasted. The guy used soda and walnut shells. An experienced man but I still ended up with some damage. The hood/bracing glue broke loose and the hood warped. I won't even mention the mess I had to deal with for weeks as hidden soda appeared out of nowhere.
Dipping works but it also has its problems. Hidden chemicals can reappear and damage your new paint.
Personally, I use sandpaper.
is teher something to put over the rusted spots to clean them up for primer. On my truck theers a bit of rust on teh doorpanels right in teh middle ive hit it with a sanding disc the d/a and jitterbugg sander put its not all gone i need to stop the rust ill be putting two part putty over this spot as i have remove a little metal and its a little scaly .
hrvat
06-23-2012 11:06 AM
scrapperdan
02-12-2006 01:25 AM
