2017 fuel filter change, clamshell?
Old Jun 14, 2020 | 09:43 AM
carcus's Avatar
carcus
Ok so I changed my fuel filters yesterday, easy job, the OEM filter came with this clamshell for the fuel return line connector, do I need this? Doesn't seem like it?
Old Jun 14, 2020 | 10:09 AM
Mattm400's Avatar
Mattm400
Yes, it's a new thing to keep the skimpy return line from breaking off. They started putting it on in factory in 2019. I mean, you don't HAVE to use it, but it's an update.
Old Jun 14, 2020 | 12:18 PM
carcus's Avatar
carcus
Ok thanks, i put it on
Old May 1, 2021 | 03:47 PM
JetFuelBurner's Avatar
JetFuelBurner
I was thinking the same thing. "do I need this". Then I read that its an update to the system. Figured I'd better put it on. Don't need to give them any ammunition to try to say xyz is not covered by the warranty because I didn't install the 15c plastic clamshell.
Old Oct 5, 2021 | 05:42 PM
SCRobert's Avatar
SCRobert
I am going to do my first fuel filter change this weekend. The kit I bought also includes the clamshell. It’s a 2019 and there is not one on it currently. I will put it on, but is this something that you replace every time, or once you put it on you’re good to go? I just figure the less I disturb that return line the better and trying to pry that plastic clamp off every time could create a problem. Is the gap they want obvious, or is it necessary to use a feeler gauge?
big315
May 13, 2016 01:08 PM
AlbyVA
6.4L Power Stroke Diesel
15
Aug 19, 2010 05:23 AM
crashman
Mar 21, 2005 02:15 PM
RoyalFord
1997 - 2003 F150
29
Aug 21, 2004 02:52 PM
janos
Jun 8, 2003 09:51 AM
