Sponsored by: Real Truck
Odd brake light problem
Old Jun 12, 2020 | 06:09 AM
Otrip's Avatar
Otrip
2004 F-250 6.0 Harley edition.
Tail lights and 3rd brake light will not turn off unless I disconnect batteries or pull fuse 116 (ignition).
No changes with key position or key removed.
When I push on the brake pedal, lights get slightly brighter.
Turn signals work normally.
Parking, clearance and headlights lights work normally.
Steps I've taken to diagnose:
Pulled every single fuse and relay in main panel and under hood.
Disconnected brake pedal switch.
Disconnected brake pressure switch.
Disconnected trailer brake controller including harness.
Disconnected tail light connector in rear.
Disconnected trailer harness in rear.
Disconnected headlight/parking switch.
Disconnected multi function switch.
Pulled 3rd brake light bulb.
Thinking something must be shorted within the ignition circuit or something always hot and not fused but I have no idea where to look, what else to disconnect or what wires to start cutting (hopefully don't have to).
Any ideas? I'm completely stumped with this one.
ike1562
Jun 14, 2020 12:31 PM
MAHighboy77
13
Feb 10, 2020 09:01 PM
strokerfe
May 8, 2011 08:15 PM
daddy dawg
Apr 1, 2011 08:19 AM
