Sponsored by: Real Truck
Bilstein Shocks
Old Jun 11, 2020 | 05:57 PM
GeorgeS59's Avatar
GeorgeS59
Bilstein Shocks
Finally got around to replacing the shocks on my 2015 F350. It had Ranchos on it when I bought it and I'm figuring they were the original shocks. The truck had 97,000 miles on it today when I replaced the shocks. It rode horribly - jarringly harsh. I replaced the shocks with a set of Bilstein 5100's. Took me 2 hrs in my driveway. I didn't remove the wheels or have to jack the truck up. The rubber isolators on the top of the front shocks were completely worn and warbled out. I took it for a spin afterwards and it definitely seemed smoother. Will have to see how it does on a longer trip. A very doable project for the average mechanically inclined.
Old Jun 12, 2020 | 12:37 PM
Brother Les's Avatar
Brother Les
Glad that you think that it is running smoother.
imo, it did not come with Rancho's, but were added later. One big clue is that you said that the rubber isolators on the top of the front shocks were completely worn and warbled out. I does not look like the rubber is in too bad condition for 97,000 miles on the Rancho's, if they were original.
Did you put the shim in the lower overload leaf (second picture)? That shim really reduces the flex of the leaf springs as the lower overload is engaged all of the time (making for a stiffer ride). Some one did not want the rear to sag or sag very little. If that is a factory shim, I question why?
I have heavy duty overload springs (upper and lower) and have no shim.
Old Jun 12, 2020 | 01:42 PM
GeorgeS59's Avatar
GeorgeS59
Whatever is there, was there when I bought it. Is the shim, the round disc looking thing between the springs? The previous owner towed a 5th wheel and so do we. Ours is 16,000lbs with about 3,000lbs of pin weight in the bed. Truck doesn't squat much at all when hitched up. I bet the previous owner didn't want it to squat with his trailer either.
Old Jun 12, 2020 | 07:48 PM
Brother Les
The bottom 'leaf' is the lower heavy duty leaf. The middle springs, when 'loaded' would squat down to the lower (heavy) leaf. The shim/round disc helps keep the middle leafs at their starting position. The stiffness of the leafs makes a stiffer ride because of less flex in the springs. Hauling a 5th wheel, these shims keep your truck from squatting and is safer for hauling for stability from side to side and reduces the porpoising effect.
I have Timbens on my truck and my over load springs do not engage.
https://www.etrailer.com/Vehicle-Sus...n/TGMRK10.html
Old Jun 15, 2020 | 09:59 AM
Log Hog Kust'em's Avatar
Log Hog Kust'em
Those shocks at 97K miles look a whole lot better than my Stock Ranchos at 55K. I swappep them out for Bilsteins and I am very happy with ride
Old Jun 16, 2020 | 01:29 AM
Boaterguy's Avatar
Boaterguy
If you really want to get excited, pick up the Bilstein steering damper, worth every penny.
natpark
Jun 6, 2017 08:31 AM
inspector747
Feb 11, 2015 02:08 PM
fbh31118
Apr 26, 2014 05:57 AM
march
Nov 11, 2013 12:25 PM
sfgiantsfan9
Nov 18, 2010 08:39 PM
