What do you think of an idiot that changed the oil in his 5.4 and only put in 5 quarts? He has 65,000 miles on his truck and I helped him change his oil. He only brought 5 quarts!! He told me that he changed the oil every 4,000 and used only 5 quarts!! The dipstick never checked the dipstick! Has he severly damaged his truck? Any comments would be greatly appreciated.
He probably hasn't done any mojor damage, but if it was to use a little oil, he wouldn't have much on reserve before it go into the danger zone.
Make sure that from now on, they use at least 6 quarts. The more oil in the pan, will help keep the oil a little cooler because it has a little longer to sit in the pan before going thru the engine again.
Jimmy
Thanks lxman. I was concerned about three things: Oil temp, oil breakdown, and (most importantly) lack of lubrication due to low oil level (not slinging as much oil). Any comments on these, especially the "oil slinging", would be appreciated. Thanks in advance.
One quart will really not hurt too much. Running a quart low is an old racing trick. I have seen a car pick up a tenth of a second in the 1/4 mile by doing this. Alot of racers do this. By running a quart low, it is less "work" for the crank to spin, not as much fluid resistance. The problem comes in when, for whatever reason, you are more than a quart low.
I personally wouldn't run a quart low but if the truck has been and not abused it will be fine.
Thanks daytoncobra. I feel the same way. I just wanted to get some other opinions, before I told my friend not to worry about it. He was talking of selling his truck. He says he has not abused his truck (hasn't pulled anything significant yet and changes oil every 4000). He just assumed that the engine oil capacity was 5 quarts. You know what happens when you ASSUME! He is real sick about this!!! I am going to put his worries to rest and let him know that the engine should be OK.
One good thing is that the slung oil is much less important on these Mod motors because the cams are in the heads and do not rely on the slung oil for lubrication.
Jimmy
