Ball Height Average
Old Jun 6, 2020 | 12:56 PM
longhaultransport's Avatar
longhaultransport
Ball Height Average
I have a question about ball height, for a drop hitch.
If I measured a hundred bumper pull travel trailers, RV style, would I come up with a reasonably close average?
If so, what would that number be?
Old Jun 6, 2020 | 02:45 PM
WE3ZS's Avatar
WE3ZS
You would definitely get the average of those 100 trailers, but that could be very different from the average of the typical trailer you might tow. My little 5x8 utility trailer has about a foot less ball height than my 12K TT, the average between those two wouldn't make for a decent height for either one in actual use.
Old Jun 6, 2020 | 02:59 PM
longhaultransport
Ok, edited to reflect my search parameters.
I'm not really concerned about utility trailers or enclosed trailers, just RV style travel trailers.
Old Jun 6, 2020 | 03:21 PM
Mickey Bitsko's Avatar
Mickey Bitsko
Rule of thumb 17" top of ball
Old Jun 6, 2020 | 04:30 PM
Pugga's Avatar
Pugga
If you’re trying to get an average for a drop hitch, then the short answer is the averages for travel trailers can vary a lot. Some frames were set high and lots of people added up using rise shanks, older trailers tended to be lower framed and a much lower ball height. If you have a model of the style of trailer you’re looking at, you could likely get close for a ball height. And by close I mean within 3 or 4 inches. My travel trailer, top of ball, is level at 20 inches.
Old Jun 6, 2020 | 04:46 PM
longhaultransport
Wow, 20 inches. Is that with flipped axles?
I was thinking the highest would be no more than 19",
Old Jun 6, 2020 | 05:28 PM
Pugga's Avatar
Pugga
just a Passport, no flip kit applied. Still had to run a pretty significant drop shank to tow it level.
Old Jun 6, 2020 | 06:39 PM
meborder's Avatar
meborder
I just measured mine. Made sure it was level and the top of ball is at 25-26” off the ground.
you are asking for averages, and it doesn’t work that way. Some are taller than others.
mine is exceptionally tall because the tongue is level with the frame, not below it like most.
Old Jun 6, 2020 | 07:19 PM
HRTKD's Avatar
HRTKD
My bumper pull toy hauler is at least 20". The axles are at OEM height, but that's with the axle under the springs.
Old Jun 7, 2020 | 12:44 AM
351Cleveland C4's Avatar
351Cleveland C4
Buy an adjustable drop hitch, and you'll be set for anything.
Old Jun 7, 2020 | 05:06 AM
Mickey Bitsko
^. Problem solved
Old Jun 7, 2020 | 08:23 AM
SpencerPJ's Avatar
SpencerPJ
Level, mine is 19" to top of coupler for a modest 21' Puma travel trailer
Old Jun 7, 2020 | 12:37 PM
WE3ZS's Avatar
WE3ZS
Just went out and measured mine, '14 Jayco 338RETS sitting on upgraded 7K axles and springs (from 5200lb) and on 16"s (vs stock 15"s) with the TT level it's exactly 29" to the top of the ball mount, it has the mid frame type mount. The driveway has a very slight grade to it so the truelevel measurement is closer to 27" I think.
Old Jun 7, 2020 | 01:38 PM
meborder's Avatar
meborder
27” makes a lot of sense.
mine was between 25” and 26” and I’m rolling on 14” tires.
so I guess if you are going to buy a hitch and hope that it works for everything, you need one that will adjust down to 14” all the way up to about 27”
im actually glad that my coupler is so high. If it were lower like the ones where the tongue is below the frame, I would have a hard time getting my coupler low enough. My hitch unloaded is at 20”, so it takes a fairly long shank for get that much drop on a WDH.
Old Jun 7, 2020 | 01:44 PM
longhaultransport
Well, I have a rapid hitch with a 6" drop and I use that for small trailers, utility, enclosed and boats, that sort of thing, but for WD hitch I purchased this shank...
I'm pretty sure it will work for 'most' travel trailers, but it is not as easy to adjust up or down.
