Sponsored by: Real Truck
Rim bolt pattern
Old Jun 6, 2020 | 11:00 AM
acjimmy8's Avatar
acjimmy8
Rim bolt pattern
Hi everyone,
My truck is a 2008 F-350 Long Bed SRW,
I haul my Northern Lite 10.2"camper a lot.
Was using LT 265/70 R17, upgrade to LT275/70 R18 last winter.
Looking to upgrade LT 265/60 R20 for more stability,and i found a OEM used set off 2017 F350 SRW
I was wondering is 2017 F350 SRW sharing the same Rim bolt pattern?
I google and found that 2008 and 2017 should be 8 X170 ,but i am not sure about the rim center bore.
Does anyone try to put 2017's 20" rim to 2008 / older model F350?
Thank you
Old Jun 6, 2020 | 12:25 PM
seville009's Avatar
seville009
According to this thread, 2005 and up trucks have the same wheels and can be swapped.
I switched tires back and forth between my 2006 and 2011 F350’s SRW
https://www.ford-trucks.com/forums/1...it-2016-a.html
Old Jun 6, 2020 | 03:54 PM
acjimmy8's Avatar
acjimmy8
Thank you for your reply!
I will then go for the OEM rim.
78bigunns
Nov 22, 2011 01:28 PM
instyle
Nov 16, 2011 04:11 PM
jstoddard
Apr 17, 2009 11:35 AM
95XL
Dec 9, 2007 08:27 AM
ron78supercab
Jan 20, 2004 04:06 PM
