Sync wiring
Old Jun 6, 2020 | 10:25 AM
17superduty350xl's Avatar
17superduty350xl
Sync wiring
have a 17 F350 XL. It bought it used. It has a Sync system and a backup camera, but the camera does not work. I'm trying to trace wiring out.
First, the wiring at the camera seems to be sound.
Rear Camera connections, white, Violet./white, Brown, White/green, green, Gray.
Then I pulled the 54 pin connector at the Sync unit.
First thing I noticed was that there were 3 'taped" wires that do NOT look like something I would expect from the factory. I chased them up the bundle and they were all "shielding" wires. But I really can't be sure about the rest of the wires. It would be really nice if I had a description of the pin-out map for this 54 pin connector. Any help?
It would be awesome if I knew for sure what these wires are expected to be, and if any are from the rear camera.
Finally, it would be cool if I knew some handy way to see what the output from the camera "should be" (something I can measure with a micro-tester.)
Any help?
Thanks
Edit
Old Oct 24, 2021 | 02:19 PM
newfolio's Avatar
newfolio
Did you find an answer?
I know this is an old thread but I too would like a description of the pin-out map for this 54 pin connector.
Old Oct 24, 2021 | 11:59 PM
mattm04's Avatar
mattm04
Try this. ive had issues with these schematics accuracy in the past so use at your own risk
Old May 10, 2023 | 12:21 PM
17superduty350's Avatar
17superduty350
4wd Low
52.Pin Out
Thanks Mattm04. Just what I needed
fixingstill
Oct 23, 2019 10:59 PM
airmissle
Jul 19, 2019 02:48 PM
Stevaroo01
Sep 30, 2017 02:51 PM
73richards250
Dec 29, 2014 01:39 PM
black58
15
Apr 5, 2009 08:31 PM
