Where can I find a 'sway bar end link' for my "78 F250, RWD, C6, 460? The drivers side rear one was broken & when I tried to remove the passenger side to use as a guide to try to see if I could make one or get one made,
the bolt on the end going into the bushing twisted off. I found a "End Link Bushing Kit" weeks ago online, but not the bar it attaches to. Not sure if it is called the "end link", but it attaches to what seems to me to be the actual
"sway bar" which runs over & attaches to the axle/rear end housing. But then again I know enough to be dangerous most of the time!
I finally found one at a local Sturdevant's auto parts place. It is a little longer, but the sway bar adjusts easily & I had a upper set of bolt holes available to make it work well!
Thank you!
