Wiring harnesses
Old Oct 17, 2003 | 09:49 PM
rick90yj's Avatar
rick90yj
Wiring harnesses
I'm putting an 86 Ford F-150 5.0, C-6, and NP-208 into a Jeep Wrangler. I need an engine wiring harness for the engine. Is there a source for them?
Old Oct 19, 2003 | 10:48 AM
Paso1's Avatar
Paso1
You really don't need much of a wiring harness on a transplant. Did you keep all the smog stuff. Are you changing out the ignition system ? Keeping the orginal computer??? Personally I would ditch everything computer related and go with a MSD 4a box and use there wiring harness. ( All three wires) makes for a nice clean install.
Old Oct 19, 2003 | 12:19 PM
rick90yj's Avatar
rick90yj
OK, I'm running the EFI on the 5.0, so I need the computer to run that. It's going into a 1990 (carbed) Jeep Wrangler. So, you see, I need the engine management system for it. And, the harness is about $300 cheaper than an MSD ignition (which in my opinion is overpriced. I paid $40 for the (homebuilt) ignition I am running and it's comparable to an MSD.)
