Trackbar hardware? thermo plug?
Old Jun 4, 2020 | 07:10 PM
Eppidemic's Avatar
Eppidemic
Couple questions. Anybody know the stock size and lengths of the hardware for the track bar bracket and track bar bushings? I just picked up a new bracket and bar and need a little assistance. I never had one installed.
Second question. I recently did some engine work and unhooked a lot of electrical and sensors. Everything is back together and I have no Thermo reading on my gauge. I have a few little plugs that go to nothing in my engine bay because of Efuel and some other deletes. Not sure which one plugs into the water pump Thermo sensor. If that is indeed the correct one. What other pigtails or wires are on the same bundle that the thermo plug is?
Thanks guys.
Old Jun 6, 2020 | 01:17 PM
Eppidemic's Avatar
Eppidemic
Damn. Nobody? I would really appreciate if somebody has an extra minute to look at their temperature plug and relay to me what else is connected to it.
Old Jun 6, 2020 | 02:04 PM
nateairman's Avatar
nateairman
Everything that was hooked to the fuel bowl goes to a plug. The thermometer wire is separate and comes down the driver side of the hpop reservoir
Old Jun 6, 2020 | 02:06 PM
nateairman's Avatar
nateairman
The track bar should just bolt in if you got all the brackets. It has rubber bushings in the ends. It should be the same angle as the steering linkage.
TheDuke
Jul 9, 2017 12:26 PM
VanGo
Aerostar
Feb 27, 2007 03:25 PM
Sagegrouse
Feb 6, 2005 07:55 PM
UncleBob75
Oct 13, 2003 12:21 PM
