Cab over master cylinder
Old Jun 4, 2020 | 06:49 PM
okiewelder's Avatar
okiewelder
So l am buying a 1960 F600 Cab over and having issues locating a new master cylinder. Has anyone ever converted one to a newer style dual reservoir? If so what did you use?
Old Jun 4, 2020 | 11:36 PM
fivestarmmd's Avatar
fivestarmmd
How are you going to hook dual reservoir to brake booster that has one line going to it?
Old Jun 4, 2020 | 11:42 PM
85e150's Avatar
85e150
You have a C600. Look at the brake and clutch to see how those clutch and brake masters sit. They are an oddball setup, and you fill the cylinder through the top where the rod goes in.
Your power booster will be a hydro-vac unit on the frame just behind the cab, further back in some models.
https://www.ebay.com/b/Brake-Master-...566/bn_1375948
A conventional firewall mounted booster would look funny sticking out of the front of the truck.
Old Jun 5, 2020 | 08:22 AM
okiewelder's Avatar
okiewelder
Yes of course a conventional master would be stupid to hang out the front of the truck! I have changed 15 or so cars/trucks over to dual master cylinders over the years and have no issues bending and flaring lines. l really didn't expect these kinds of replys to my question but, thank you guys for your great wisdom!
Old Jun 5, 2020 | 06:22 PM
53deere's Avatar
53deere
I don't know how the C series are mounted but I've made mounts in the past to mount dual master cylinders down on the frame for old ****** jeeps. Should be a doable project on a C series. The dual master cylinder would require two boosters if you want power brakes unless someone makes a dual in/out booster. I remember getting boosters off of something years ago in a scrap yard and it used two separate boosters though.
Old Jun 5, 2020 | 08:50 PM
fivestarmmd
I guess I don't understand why it needs dual master cyl when the orginal system has worked for 60 years and had enough braking capicaty to stop it loaded to rated GVW in a specified distance. Once the wheels lock all control is lost.
Old Jun 6, 2020 | 06:11 AM
53deere's Avatar
53deere
It's not about stopping power, it's a safety issue. Nothing wrong with trying to add a safety feature to an older vehicle.
Buckley
Aug 24, 2020 07:53 AM
Tim Hodgson
1978 - 1996 Big Bronco
Jan 29, 2019 10:18 PM
dogg16
Bronco II
Sep 14, 2004 04:19 PM
jeffh
28
Nov 25, 2002 09:56 PM
