Stuck in 4th
Old Oct 17, 2003 | 05:56 PM
limaspiderman's Avatar
limaspiderman
Stuck in 4th
I have a 91 Ford Rangerw/4.0 & 5 speed manual. The transmission is stuck in Forth. I have removed the transmission & am attempting to disassemble it. I am having trouble removing the input shaft. The tranny was VERY low on oil. I believe a bearign might be seized. I have removed the tapered roller bearings on both ends , but not the middle. Any suggestions? I believe if I can get in input shaft off I can get to the problem. Thanks!!!!!!!!!
