crankshaft position sensor
Old Oct 17, 2003 | 04:00 PM
mrcobra350's Avatar
mrcobra350
Cool crankshaft position sensor
After reading your posts last night. I decided to change my CPS. You will notice I call it a crank pos. sens. That is what it really reads is the crank not the cam. I took ya"lls advice and called local Ford dealer in Greenville. Didnt have it in stock $180.00 so I looked up the local International dealer and they had it in stock and for only$78.47. I was amazed. I went and got it and put it in in my driveway in about 20 minutes. Mine is a 95 and it took the early sensor. The new part number is 1821720C99.
They said it has been updated several times. I was a Ford tech for 23 years but dont know a lot about the powerstroke but I am learning. My truck has been intermittently stalling at idle for a year so decided I better replace it.
Thanks to everyone for all the great words of wisdom hope I can return the favor someday.
Rick Carson
PS I saw someone said the box said something besides sensor my box said transmitter on it. So you never know what the box might say.
Old Oct 17, 2003 | 04:56 PM
International Tech's Avatar
International Tech
BTW it reads the trigger wheel on the camshaft.
Old Oct 18, 2003 | 07:53 AM
powerstroker250's Avatar
powerstroker250
Yep
Old Oct 19, 2003 | 04:30 PM
mrcobra350's Avatar
mrcobra350
Thanks for the info. When I called the Ford dealer and asked for a cam position sensor he came back and said do you mean crank position sensor. So I assumed it may have been another misprint in the books.And since it was right beside the harmonic balancer. You know the rest of the story. Thanks again for keeping me straight.
BTW my truck has not stalled since replacing the part and I swear it seems to idle better. I know it has to be my imagination.
Old Oct 19, 2003 | 06:58 PM
International Tech
no problem. no harm done. the new 6.0l or VT365 has a crankshaft position sensor as well as a camshaft position sesnor. good to here shes running good.
Old Oct 19, 2003 | 07:15 PM
mrcobra350's Avatar
mrcobra350
Thanks Int. Tech. I just noticed we are practically neighbors. I am not far from Greenville.
I came real close to trading for a 6.0 liter. Then I decided my truck runs perfect and its paid for.
Now that I got the stalling problem corrected now I can work on that pesky overheating trans problem and it will be good as new.
Thanks again for your help.
Old Oct 19, 2003 | 07:29 PM
International Tech
lil hint. Dont trade for the 6.0. Since im a Int Tech all the customers that have had the 7.3 (T444E) engine that traded trucks for the 6.0 (VT365) really miss the T444E. Again this is in med duty trucks towing alot heavier loads than the Ford trucks do.
Old Oct 19, 2003 | 07:38 PM
mrcobra350's Avatar
mrcobra350
Thanks for the tip. After reading some of the stories on here. I thought it would be smart to wait. Having worked at Ford dealers for 23 years I know how they use the consumers for guinea pigs and the techs too.Thats why I gave it up.
Old Oct 20, 2003 | 12:12 AM
johnsdiesel's Avatar
johnsdiesel
Not only that, it's not called a CPS. Ford calls it a CMP Sensor and International calls it a CAMP Sensor.
Old Oct 20, 2003 | 06:42 AM
International Tech
YEP.
Old Oct 20, 2003 | 06:47 PM
mrcobra350's Avatar
mrcobra350
Well at least I spelled Ford right and got the right engine. I Think.....
Old Dec 14, 2012 | 10:55 AM
epxpc's Avatar
epxpc
I have a Gas 7.5L and in doing a scan I get a code that states a problem with the CPS. Thing is the truck runs great. Any ideas?
Old Dec 14, 2012 | 12:53 PM
woodnthings's Avatar
woodnthings
You posted in the 7.3L Diesel section from a post that is 9 years old....You may want to look elsewhere for your answer to get a speedy and relevant reply.
Old Dec 14, 2012 | 04:44 PM
trekbasso's Avatar
trekbasso
Man, I need to start looking at the dates also. But, I am still curious why he paid 70+ at the Intl dealer.
Old Dec 14, 2012 | 10:46 PM
woodnthings
If you haven't had a 7.3L for a long time, you wouldn't know that the OEM Black CPS used to fetch $150-180 at the dealers. So International selling them for $70-80 was a screaming deal! After the recall, they dropped to under $30
