Engine lift question
Old May 25, 2020 | 12:13 PM
Scotty's 52 F3's Avatar
Scotty's 52 F3
I'm with Ross, use a 3/8 or larger bolt hole if you can. I usually use a lifting link or a bolt with a large washer through a chain link. I've used a come-along to lift one end in a three point setup to be able to tilt the load. Probably overkill in this case with no cab in the way. Good luck and be safe.
Smoking Joe
May 5, 2019 04:27 PM
hulleywoodworking
May 4, 2015 12:41 PM
Garst250SD
Sep 13, 2011 06:45 PM
metalskater2
May 23, 2010 08:26 PM
e-tek
1947 and Older Ford Trucks
Jul 17, 2008 11:48 PM
