CDR Grommet
Old May 25, 2020 | 12:22 AM
SD83's Avatar
SD83
CDR Grommet
I’ve got an 86 6.9 N/A. I bought a new CDR and grommet, the original had the metal tube going in to the valley pan. When I removed it the old grommet was not on the tube. My question is, how is the grommet oriented on the tube? There is a ridge on the tube, does the grommet go below or above the ridge?
Old May 25, 2020 | 08:46 AM
lonewolf_'s Avatar
lonewolf_
Scope Wizard
it's pretty straight forward......
There is also this style https://swagperformanceparts.com/7-3...e-grommet-kit/
here is another picture using the metal tube the Lip does not go inside the valley pan grommet.
Old May 25, 2020 | 10:53 AM
SD83's Avatar
SD83
Thank you sir, not at all what I thought. Is there a replacement seal available for where the tube goes in to the valley pan?
Old May 25, 2020 | 11:52 AM
lonewolf_'s Avatar
lonewolf_
Scope Wizard
E3TZ-6A892-A (1) & E8TZ-6A892-A (1) generally they come with the new CDR valve
finding the short Grommet for use with the metal tube is a bit harder to find ... Flea Bay maybe the short Grommet generally comes with a new Valley Pan/ aka intake manifold gasket.
I guess you could cut the long one down... there is an AC Delco one for GM and 1 for dodge that I think works but I don't have information handy on them... someone had posted that here in these forums some time back.
Old May 25, 2020 | 03:39 PM
Charmalu's Avatar
Charmalu
I ordered a new CDR a few years ago and the new CDR has a short tube and a long hose and the
gromet part of the hose where it inserts into the Valley Pan.
Here is a link that shows the assy.
https://pensacoladiesel.com/product/...crankcase-kit/
Charlie
Old May 25, 2020 | 03:57 PM
lonewolf_'s Avatar
lonewolf_
Scope Wizard
I think this is the GM one that works but don't Quote me on it...... 6.5 CDR Valve Grommet :: SSDiesel Supply :: GM 6.5 TD Specialists
since you already got the new CDR valve you should be able to use FORD E3TZ-6A892-A (1) & E8TZ-6A892-A (1)
Old May 25, 2020 | 07:34 PM
SD83's Avatar
SD83
Thanks fellas, I found that part on amazon
ranger140892
Jun 2, 2018 11:11 AM
JD_F250
Oct 27, 2014 06:33 PM
64fordf100292
Sep 7, 2011 10:39 AM
3TreeGuy
Jan 28, 2010 09:20 PM
jjlrrw
1997 - 2003 F150
Sep 30, 2007 08:36 PM
